How convert to Jpeg2000?
Post by Guest »
How convert to Jpeg2000 format?
Bad output format 'jp2'
Re: How convert to Jpeg2000?
Anonymous wrote:How convert to Jpeg2000 format?
Do you have the jpeg2000 plugin?
Post by Guest »
do i need one!? :twisted:
ok i copy/paste plugins dir from xnview so it converts now.
But i was unable to get 32bit jpeg2000 image.
how convert to 32bit jpeg2000?
Anonymous wrote:do i need one!? :twisted:
32bits is not possible with Jasper plugin, try the lurawave one
Post by Guest »
gives 24bit jp2 image
gives some rubish image
actual 32bit png:
btw what option for jp2 compression quality?
Post by Guest »
xnview wrote: 32bits is not possible with Jasper plugin, try the lurawave one
hmm... actualy after repeated tests i noticed that JasPer plugin converts to 32bit, and i was able to convert back to png and got correct alpha,
but lurawave compressed without alpha.
noticed that current JasPer Version is 1.900, nconvert use v1.701.
so what option is for jp2 compression quality?
Anonymous wrote: noticed that current JasPer Version is 1.900, nconvert use v1.701.
Right, i'll update
Quality
Me
Post by Me »
I tried to convert dds to jpeg2000 with alpha plane using xnview but i get a DXT1 without any alpha plane
I tried to use the nconvert using the parameter
nconvert.exe -v -out lwfjp2
and
And i get
Bad output format
I copy the dll from xnview too but i get the same error
I'm using the 5.02 version and i don't see any reference about jpeg2000
Yes i have the plugins
Maybe in the 5.02 this plugins/options are gone?
Thanks !!!
Me wrote: I copy the dll from xnview too but i get the same error
The dll's are in Plugins folder?
Me
Post by Me »
Thanks a silly mistake, and what a about to get the mipmaps of the DDS files?
Actually i only can convert to DXT1 with 1 mipmap?
Thanks!
