Contact sheets of a lot of movies at once?
SpeedDevil
Post by SpeedDevil »
Is it possible to select a group of movie files and have the program generate contact sheets for each movie and save them in the same directory?
Like
moviea.avi
movieb.avi
etc
SpeedDevil
bump
You can try "Video Gallery Thumbnail"
SpeedDevil
"Video Gallery Thumbnail" only works on ONE file at a time, and it doesn't save the picture. You can't give it 500 files and go away while it works.
I'll try and have google translate that:
"Galerie de vignette vidéo" ne fonctionne que sur un seul fichier à la fois, et il ne permet pas d'enregistrer l'image. Vous ne pouvez pas lui donner 500 fichiers et disparaissent alors que ça marche.
SpeedDevil wrote:"Video Gallery Thumbnail" only works on ONE file at a time, and it doesn't save the picture. You can't give it 500 files and go away while it works.
Sorry but i didn't remember that "video gallery" works only on one video file...
