Twin monitor setup: Initial window pos & size
riczito
Post by riczito »
I set XnView to "remember" last used window size and location : maximised on my second monitor. Unfortunately, every time it launches it still opens on my primary monitor (although it does remember to maximise).
Can this be fixed? :?:
Apart from that, XnView is terrific! :D
Bravo Pierre, c'est du super boulot, rapide, élégant et très bien conçu. Que vouloir de plus?
félicitations,
Ric
Re: Twin monitor setup: Initial window pos & size
riczito wrote:I set XnView to "remember" last used window size and location : maximised on my second monitor. Unfortunately, every time it launches it still opens on my primary monitor (although it does remember to maximise).
Ok, i'll try to fix this problem!
Merci. Pierre.
