colour depth
colour depth
Post by Guest »
Hi - I suspect this is a very basic question, but looking through the command line options I couldn't find the right one. Do you know how (if) I can specify the bits per pixel of an output image using nconvert?
Cheers,
Ben
Re: colour depth
Anonymous wrote:Hi - I suspect this is a very basic question, but looking through the command line options I couldn't find the right one. Do you know how (if) I can specify the bits per pixel of an output image using nconvert?
You can change the bits per pixel with -colors or -grey or -binary
