I think I have found a problem with the "Delete to recycle bin" option unless I am missing something.
I have this switched on and when you delete an image from the main browser view in doesn't put the deleted into the recycle bin, which is what I would expect.
However, if I work in Batch processing mode and process many images at once then the image gets put into the recycle bin. I use the overwrite option of replace and have tried the delete original check box on and off and it still does it.
Is this a bug or is there something else I need to do to stop the batch processing from using the recycle bin.
Thanks
Gav
Deleting Images to the recycle bin
gavp
bugmenot
