Multiple .ico file display
nightflyer
Post by nightflyer »
Is there a way to display in the browser the biggest icon from .ico file, not just the first?
-=nightflyer=-
Nope
:arrow: nightflyer
:) Hello !
• AFAIK, nope ! You can view multipage ICO formats only in View mode. Morerover, the huge 256² Vista icons
(PNG compressed) are not supported (yet…).
- That leads to get an error message when such an ICO contains a 256² format,
instead of getting the display of the other “normal” pages… :(
- Workaround :  Via «Open with…», you could use GFIE (Freeware) which supports all ICO formats
(and is a good painting tool, you can change the ICO at will with it).
:mrgreen: KR
