Why is image reduced in file size after processing?
Billy Budd
When I process or adjust images in XnView and elect to overwrite the original image, the size of the file is greatly reduced--from 3 or 4 MB to 500 or less KB. Why? Is there any way I can avoid this result? Thanks
festina lente, make haste slowly
Re: Why is imaged reduced in size after processing?
Do you have checked option/Write/Jpeg/Quality?
Billy Budd
Just to make sure: When JPG compression is lossy, that means when saving the image the image is not saved 1:1 but modified a bit for better compression. In Wikipedia the compression is described in more detailed.
Topic 'Lossy? Lossless? 256 colors? This is confusing!' also contains valuable information.
