B1: JPEG settings for batch processing not saved
silverfire
Post by silverfire »
JPEG settings are rest to 80/Slow/2x1,1x1,1x1 every run.
To test:
1 - Set JPEG settings to 95/Float/1x1,1x1,1x1 and convert an image in batch processing
2 - Open batch processing dialog again and check JPEG settings
Re: B1: JPEG settings for batch processing not saved
Yes there is a reset of Write settings when you quit batch convert.
