Fullscreen - two issues
DireStrike
Post by DireStrike »
Both of these apply to trying to open a file from outside of xnview with xnview. If I open xnview and then open the file through there, these problems don't happen.
1) When I try to view a specific image in fullscreen, it instead just shows the first image in the folder. How do I fix that?
2) I'm trying to get it to display the image size. It doesn't seem to listen to my settings changes at all for information to be displayed with the image. It shows the default <path><filename> no matter what I put in there.
Re: Fullscreen - two issues
DireStrike wrote: 1) When I try to view a specific image in fullscreen, it instead just shows the first image in the folder. How do I fix that?
Seems to be related to
http://newsgroup.xnview.com/viewtopic.php?t=12356
You change option/Fullscreen/Info?
DireStrike
Yep, first problem was that. Changing the key fixed it and it hasn't come back.
Second problem - Yes, that's what I changed, the text in the box. It didn't seem to do anything. However, the problem seems to be gone now... *shrug*
Thank you.
