I want to display DWT (Drawing Templates), which are the same file like AutoCAD DWG, but only the extension differs DWG / DWT.
Is this a job for XnView or a job for Cadimage-Plugin?
Peter
Displaying DWT (AutoCAD DWG template)
Peter2
Re: Displaying DWT (AutoCAD DWG template)
Ok i'll add this extension!Peter2 wrote:I want to display DWT (Drawing Templates), which are the same file like AutoCAD DWG, but only the extension differs DWG / DWT.
Peter2
Thanks.xnview wrote:Ok i'll add this extension!
Peter
Peter2
Cadsofttools released a beta version of cadimage.dll with DWT-Support, but it does not works - I think the problem is the missing extension in XnView?
http://www.cadsofttools.com/forum/viewt ... f=4&t=1356
Peter
Peter
When 1.94 beta 3 will be available, please try itPeter2 wrote:Cadsofttools released a beta version of cadimage.dll with DWT-Support, but it does not works - I think the problem is the missing extension in XnView?
Peter2
DWT is the same as a DWG (only other extension), and here http://cadwiesel.de/ under "Bibliothek" you will find many DWGs. Load and rename them.helmut wrote:... provide a DWT sample file on a download server. ...
Peter
O.k., thank you for the info and link, Peter2!Peter2 wrote:DWT is the same as a DWG (only other extension), and here http://cadwiesel.de/ under "Bibliothek" you will find many DWGs. Load and rename them.
