I have a multi-frame-tiff with 17 Frames. When I use "extract all", all frames from frame 2 - 17 are extracted. Frame 1 stays unchanged, and I have to edit to file (delete all frames from 2 til 17) to get my single frame 1.
Is there a better way?
Peter
[Solved] Multi frame TIFF - extract all
Peter2
Re: Multi frame TIFF - extract all
Yes, Multipage - editPeter2 wrote:I have a multi-frame-tiff with 17 Frames. When I use "extract all", all frames from frame 2 - 17 are extracted. Frame 1 stays unchanged, and I have to edit to file (delete all frames from 2 til 17) to get my single frame 1.
Peter2
This is what I meant to be "uncomfortable". The "extract all" function should extract all frames - including frame 1.xnview wrote:Yes, Multipage - edit
Peter
fritzxnview
Oh sorry, ok it's a bug
Peter2
I have to correct my posting: Not the first page is unextracted, but the current-displayed page will not be extracted.Peter2 wrote:...When I use "extract all", all frames from frame 2 - 17 are extracted. Frame 1 stays unchanged, ..
Peter
Peter2
