Exif information in picture sublines not shown correctly
Fraenzken
Post by Fraenzken »
I've configured XnView so that it shows several Exif information under the thumbnails in the browser mode, e.g. ISO, shutter speed, focal length etc. The information are shown correctly with jpgs that were generated by my camera (Olympus E510), but not when I convert the Olympus RAW files with Bibble to a jpg file. The Exif data are embedded correctly, as can be seen in XnView using <ALT>+<ENTER>; they are just not displayed under the thumbnails. You can find an example here:
http://www.reisefotos-web.de/test/P6243105_1.jpg
Thanks,
Frank
Re: Exif information in picture sublines not shown correctly
Right, i'll check
Fraenzken
Post by Fraenzken »
Thanks!
B.t.w., thanks also for the fixed reading of the embedded thumbnails in orf files - it seems to work great now. :D
Frank
