Hi
Is there any doc, way, exemple, or anything else to integrate to XnView a new image file format ?
If I don't make mistake, XnView does not support ENVI File and I project to integrate this format to XnView.
thanks
ENVI File format
Sample
• It's obvious that you can't add a non-supported format…
• Whether it's not a closed¦proprietary one, you could send a sample to the Author for parsing to
webmasterATXnViewDOTcom
Re: ENVI File format
You have the Format SDK here
http://www.xnview.com/download/plugins/ ... DK-win.zip
