I have discovered the following problem:
My system opens images in full screen display in XnView, when I double click the file in Explorer. Pressing page down goes to the next file in directory. However, the order is always by name.
Can this be fixed, please?
To get the files ordered by date, I have to press return to open to the XnView file browser, and then go back to full screen view.
By the way, files are ordered by date in Explorer too.
Thanks for this wonderful viewer!
PS: If I might add another thing: The full schreen view first shows (for about 1/4 second), and oversharpened, ugly version of the image. I do not want to see this, and simply wait for the correct view. Can this be avoided?
Navigation ordered by Date
SinMike
Re: Order by Date
Options->Fullscreen->Uncheck 'Use delayed high quality'... I think, this is it.Rene wrote:PS: If I might add another thing: The full schreen view first shows (for about 1/4 second), and oversharpened, ugly version of the image. I do not want to see this, and simply wait for the correct view. Can this be avoided?
Re: Order by Date
Yes viewer use the sort order of xnview browserRene wrote: My system opens images in full screen display in XnView, when I double click the file in Explorer. Pressing page down goes to the next file in directory. However, the order is always by name.
Re: Order by Date
But only, if browser was opened before. Not, when the viewer opens a double clicked image. That is the problem.Yes viewer use the sort order of xnview browser
Re: Order by Date
Ok, right for some sort order, which sort setting do you use?Anonymous wrote:But only, if browser was opened before. Not, when the viewer opens a double clicked image. That is the problem.Yes viewer use the sort order of xnview browser
