Hi there,
I'm using XnView to output an individual .png for every layer in a .psd. It seems to do this very well (Menu->Tools->Multipage File->Extract All Into..).
However it seems that it is automatically trimming each of my layers based on the transparent pixels around them (they are animation frames sitting on with alpha transparency).
Because each frame is trimming down to the smallest rectangle containing non-alpha pixels, they end up not being positioned correctly relative to one another.
Is it possible to stop it from doing this trimming / cropping?
Cheers,
Ricky
Trimming of psd layers in a multipage file?
Re: Trimming of psd layers in a multipage file?
Currently not possible, xnview extract all layerrickyh wrote: Is it possible to stop it from doing this trimming / cropping?
