is there a list and description of the custom thumbnail parameters i can change within my .ini file? for example, i wanted to have the number of pages in a multipage .tiff stack (that's my current obsession now:) displayed, and i was also wondering if there was a way to change the font size for the description, or to have all the labels together on one line...
thanks for making an awesome program...i've been looking for ages for this!
Custom Thumbnail Label Parameters?
marsh
Use insert button for command list.
Options... Browser>Thumbnails>Thumbnail Label> Place Custom # in right column > Use insert button [>>] found at lower right to display a list of commands to place into Custom [_____] field.
dk
marsh
I don't think that exists, you might be first to suggest it though.dk wrote: just two things tho--do you know what command is for # of pages/frames? (i would think it'd be like <Page> or something, but that didn't work![]()
For some old v.1.X version & Win2k, Windows has display setting such as ">Icon" which increased font size/style in columns view once upon a time (probably labels too, but you should check to see if this still applies).dk wrote: and is there a way to adjust font size for the labels?
dk
i will do that.marsh wrote:I don't think that exists, you might be first to suggest it though.dk wrote: just two things tho--do you know what command is for # of pages/frames? (i would think it'd be like <Page> or something, but that didn't work![]()
i think you're talking about display properties, then appearance, and then putting font size as large--tried that, but doesn't affect font on thumbnails..will also suggest that as well. thanks for your help.marsh wrote:For some old v.1.X version & Win2k, Windows has display setting such as ">Icon" which increased font size/style in columns view once upon a time (probably labels too, but you should check to see if this still applies).dk wrote: and is there a way to adjust font size for the labels?
me
Not yet, currently i use the font from windows settings for listviewme wrote:I've just spent an hour futzing around with every conceivable font size setting both in the Windows GUI and various registry locations, but it looks like none of these have any influence whatsoever on the font size of my labels![]()
Is there any secrit .ini magic for this?
Pretty please?
