"Smooth" image browsing/viewing using the keyboard
rfrank
Post by rfrank »
Hi all
I've been using this software and ACDsee for a while and ive found this one to be a better choice for all my needs.
However, one thing that keeps disturbing me is the viewer...
When you Zoom an image you can "move" along it using the keyboard arrows, but this "movement" is attached to the keyboard properties on the control panel.
What i'm trying to say is: if you press "right" on the keyboard in a zoomed image" the viewer makes a movement to the right, followed by a little pause and then it keeps moving the scroll to the right until it reaches the end of the image.
However, on the ACDSee viewer if you press "right" on the arrows, it just keeps moving to the right with no pauses at all with a very smooth movement.
So, my suggestion (If possible), please make the movement "smoother" for hte viewer when you zoom in the image's viewer....
Thanks again!!!!!!!!! :D
BTW... What happened with the Xnview 2 with unicode support development, any news yet? :idea:
Re: "Smooth" image browsing/viewing using the keyb
rfrank wrote:BTW... What happened with the Xnview 2 with unicode support development, any news yet? :idea:
:arrow: XnView MP
