While in edit fullscreen, as you use shift+page down/up to view individual pages in a multipage file (tiff or pdf), it would be nice to have one shortcut key to delete the page you're looking at.
Currently, you have to press ctrl+J, then scroll through and select the page you want (which could take awhile if you have a many pages, or all the pages look alike), and then press remove, and then ok. I tried making shorcut with HotkeyP, but because the specified page to delete is always different, it's difficult to shortcut this.
Thanks for making this great program-it does nearly everything I want otherwise..
Multipage file-Shortcut key for deleting viewed page
dk
Re: Multipage file-Shortcut key for deleting viewed page
Currently you can only edit multipage tiff in 'TIFF edit dialog box'
