Shimmy
Post by Shimmy »
Works in old…
:arrow: Shimmy
:) Hello !
• I confirm, it doesn't work in 1.94 ß3…
… but it works alright in an old 1.82.4…
… and in "Imagine", Universal Viewer.
:mrgreen: Kind regards,
ouistiti
Post by ouistiti »
:arrow: Shimmy and Clo
That's an animated PNG, it might work in XnView 1.94-ß3, but I confirm that it doesn't.
- Indeed, the special frame "not supported" (in the case, the :wink: smiley) is displayed in old versions and other viewers…
BTW, there is a single iteration (loop), it needs F5 in Firefox to restart it…
Friendly
Paul
1,77245385090552...
Shimmy
Post by Shimmy »
ouistiti wrote:BTW, there is a single iteration (loop), it needs F5 in Firefox to restart it…
Only if your cache is disabled!
You'll need to clear your cache and then to reload.
Ok, this APNG file seems to have an error...
marsh
Crash in emulator
Post by marsh »
It is visible in v.1.94 RC1, but it crashes viewer (using Wine) when navigating from APNG to the next image (using <pg dn> key).
Settings:
Read Ahead/Cache behind disabled.
Browser>Fullscreen>Viewer (Switching mode <Enter>)
Details view
Ditto
:arrow: marsh
:) Hello B. !
• It crashes the programme as well under XP-Pro SP1, same behaviour :
1. Displayed normally,
2. Usual Bill's error message >> Close
:mrgreen: KR
Shimmy
Post by Shimmy »
Thanks for fixing ;)
Tools >> Multipage file >> Extract All (few errors with a few frames) :bug:
Alas---
:arrow: All
:) Hello !
• Still the same crash here with 1.94.1 and XP-Pro SP1… :(
:mrgreen: KR
oops66
Re: Alas---
Post by oops66 »
Clo wrote::arrow: All
:) Hello !
:mrgreen: KR
Hello Clo,
I also had this crash with this apng file (in v1.94.1), but with a fresh xnview.ini file I have solved this problem.
(FYI: I still have this crash with my previous .ini file, but i do not know why !)
So maybe you can also make a new test to see ...
Re: Alas---
Post by Guest »
:) Hello !
:mrgreen: KR
I'm using Windows Vista (Home Basic)
Shimmy
Re: Alas---
Post by Shimmy »
:) Hello !
:mrgreen: KR
Oops! sorry!! It's me, Shimmy :P
