... but can't get it to work!
Have tried:
- C:\Utility\XnView\Xnview.exe INI C:\Utility\XnView\test.ini
C:\Utility\XnView\Xnview.exe INI=C:\Utility\XnView\test.ini
C:\Utility\XnView\Xnview.exe -INI C:\Utility\XnView\test.ini
C:\Utility\XnView\Xnview.exe -INI=C:\Utility\XnView\test.ini
So... what is the correct syntax to cause XnView to start with a designated INI file?
TIA
