IPTC, XMP, EXIF in MS Explorer Details
Peter2
Post by Peter2 »
(Shelldetails? Shellinfo?)
I don't know how it works and I don't know how to describe it correctly, but I will try ...
In MS Explorer you can display a lot of additional information like bitrate, length of video, last access, .... But you can not select (display) IPTC, XMP or EXIF - data. Installing the software "PixVue" adds EXIF and XMP-information, but no IPTC.
Suggestion:
Add the features to XnView so that it is possible to display IPTC, XMP and EXIF data in MS Explorer columns.
Peter
Dreamer
Post by Dreamer »
Dreamer
Peter2
Re: IPTC, XMP, EXIF in MS Explorer Details
Post by Peter2 »
Peter2 wrote:(Shelldetails? Shellinfo?)...
I found a program (not tested!) which does what I am looking for:
http://photothumb.com/IPTCExt/
If these functions would be integrated ....
Peter
