Information is not shown correctly in Viewer / Slide Show
Dreamer
Post by Dreamer »
- In fullscreen (both modes) it's working good, if there is not enough space in one row, the rest is shown in the second.
- In Viewer and Slide Show (window mode, not maximized) the part is shown in the second row, but the whole name / info is not visible, the rest of the first row info is outside the screen.
Dreamer
Dreamer
Post by Dreamer »
Not fixed in v1.94. I'm using Windows Vista 32 bit.
Dreamer
Dreamer
Post by Dreamer »
- when using "Top-Left" option, it's OK, but if the name is very very long and without spaces, then it's not fully visible, e.g.:
111111111122222222223333333333444444444455555555556666666666777777777788888888889999999999000000000011111111112222222222.jpg
Perhaps it's OK, but for users using small window and long names without spaces it might be a problem.
- when using "Top-Center" (or Center...), left part of the screen is not used for text at all, therefore name is not fully visible, in any mode
- when using "Top-Right", it's not visible at all!! in any mode!
1.95 beta 1, Win Vista.
Dreamer
Dreamer
Post by Dreamer »
Looks fixed in beta 2 (except that very long name).
Moved to Feedback.
Dreamer
Dreamer
Post by Dreamer »
OK, I think I can close this one.
Dreamer
