Several suggestions from a former ACDsee user
The Sheik
Post by The Sheik »
First off, great program, I've given up ACDsee. I do have a couple of suggestions however:
- Easier to read small icons would be great. You can't really see the "jpg" or whatever text on them when they're small.
- Zooming is done by + and -, which makes perfect sense, however you have to hold shift to hit +, so in ACDsee and other apps they let you use = as well.
- Fit image in the right click menu would be nice
- More than one image read ahead, and backwards read ahead when cycling backwards would be cool
- Add all doesn't work in associations in view as extension mode
- A "Safe all" associations where it won't steal any
Sometimes my hard drive goes nuts when paging through large amounts of images, not sure what the thrashing is about.
Re: Several suggestions from a former ACDsee user
Sheik,
thank you for your accolade and suggestions. Below please find some notes.
The Sheik wrote:...
Right. The icon set needs some rework.
The Sheik wrote:- Zooming is done by + and -, which makes perfect sense, however you have to hold shift to hit +, so in ACDsee and other apps they let you use = as well.
I guess you have an arabic keyboard. Looks as if your keyboard layout is different from the English & German. So '=' might make sense.
The Sheik wrote:- Fit image in the right click menu would be nice
Correct. We have many tools in the context menu, but not 'View >uto Image Size'. The context menu really needs some tidy up.
The Sheik wrote:- More than one image read ahead, and backwards read ahead when cycling backwards would be cool
Might be useful, but a question of memory.
The Sheik wrote:- Add all doesn't work in associations in view as extension mode
I don't understand what you mean.
The Sheik wrote:- A "Safe all" associations where it won't steal any
Not clear on this one: Do you mean a "Save all" button in Tools > Options > Associations?
The Sheik wrote:Sometimes my hard drive goes nuts when paging through large amounts of images, not sure what the thrashing is about.
What does "large amounts of images" mean? 1,000? 10,000? How large are the images? Could it be a problem of memory available?
The Sheik
Post by The Sheik »
Thanks for your blazing fast response! I'll try and clarify a few things:
I have a standard microsoft english keyboard. What i mean is that without hitting shift, the two keys are "- and =" and if you hit shift "_ and +", so to zoom in you must hit shift and press the += key. If it worked for + or = then there would be no need to hit shift.
It could be an option. Enabling the single read ahead by default might make sense too, since most users probobly turn it on anyway.
In the Options/Associations menu, if you click the "View as Extension" radio button, then click "Add all", nothing happens.
I mean an option to set the file associations for all files to XnView, unless another application is already registered with that extension.
It's a directory of 1,000 images, it totals about 215 megs and the files are of fairly consistent size, all jpegs.
The Sheik wrote:I have a standard microsoft english keyboard. What i mean is that without hitting shift, the two keys are "- and =" and if you hit shift "_ and +", so to zoom in you must hit shift and press the += key. If it worked for + or = then there would be no need to hit shift.
Ok, i'll add it
Yes, some users ask for this option.
Associations are not changed??
And what's happened?
Post by Guest »
Thanks for your quick reply, your efficiency is amazing.
No, it doesn't even change the check boxes in the GUI.
xnview wrote:
helmut wrote: What does "large amounts of images" mean? 1,000? 10,000? How large are the images? Could it be a problem of memory available?
Occassionally, every hundred images or so, I get serious disk activity and a delay of maybe 20-30 seconds to change to the next image.
Dreamer
Post by Dreamer »
xnview wrote:
helmut wrote: Might be useful, but a question of memory.
What about this? - Read ahead [A] (A=custom number of images)
Or this? - Read ahead MB (B=custom number of megabytes)
Of course also for "Cache behind" - Today, 512 MB RAM is a standard, so it would be nice...
The Sheik wrote:Enabling the single read ahead by default might make sense too, since most users probobly turn it on anyway
Yes, some users turn it on, but other users might think it's slow and they uninstall it before they try it... :(
Which OS do you have? And if you use "Add most used"?
Do you have "read Ahead" & "cache behind"? Pictures are all in jpeg format?
I can confirm this (XnView 1.74, Win XP): In "Tools > Options > Associations", when selecting "View as Extension", then pressing button "Add all" and confirming the message box, only some few extensions are marked and added. Looks like a bug :bug:
Dreamer
Post by Dreamer »
helmut wrote:
The Sheik wrote:In the Options/Associations menu, if you click the "View as Extension" radio button, then click "Add all", nothing happens.
Me too (Win XP SP1), I think it has a same function like "Add most used" button.
The Sheik
Post by The Sheik »
Windows XP Pro. It looks like it does add 10 or so if I hit add used or add all, just not as many as it adds in the view extension mode.
I have read ahead and cache behind set, and all pictures are indeed in jpeg format.
aardvarko
Post by aardvarko »
Can also confirm occasional freezing/hanging in folders with large (more than a few thousand) JPEGs. Seems to occur primarily when changing between images in View mode, although I think it's also occurred just while rendering thumbnails.
I've seen this both with locally stored files and with files stored on a Samba server; when XnView stops responding in this fashion, the smbd process on the server starts consuming 100% CPU, and the count of open handles for XnView changes up and down by a few - as though it's repeatedly fetching a directory listing. Next time it does this, I'll grab a snapshot of open handles.
Could you disable these options, and tell me if you have always the problem? Perhaps you can try to disable the cache too??
