I downloaded nconvert and ghostscript, i can convert an eps to jpg in GUI, but when i use the nconvert, it stops at license msg, no further error msg. I had to ctl-c to stop it. Can u help? thanks
C:\Program Files\XnView>nconvert -npcd 2 -size 256x256+0 -ctype grey -corder int
er -out jpeg -o c:\test.jpg c:\test.eps
** NCONVERT v5.00 (c) 1991-2008 Pierre-E Gougelet (Jul 21 2008/11:03:31) **
Version for Windows NT/9x/2000/Xp/Vista (All rights reserved)
** This is a freeware software (for non commercial use)
^C
nconvert not working, stops at license msg
houston
nconvert cannot convert from .eps
I tried several different format, .eps->tiff (NO) .psd->.jpg(YES) .psd->tiff(YES) seems like the .eps isn't working for me. I can view it in the GUI and convert it in batch mode in GUI, just not nconvert
C:\Program Files\XnView>nconvert -out jpeg c:\test3.psd
OK
OK 1
Conversion of c:\test3.psd into c:\test3.jpg OK
OK
OK 1
Re: nconvert cannot convert from .eps
Could you send me the eps file?
