When I use LoadBitmap to open a GIF or PNG, transparency info is lost and I can't find any way of retrieving it.
Is there any plan to address this? What sort of time frame?
Perfect happiness:
Alpha transparency remembered when loading from a full colour PNG. Pixel transparency remembered when loading from a colour-indexed file with transparency. (Might as well load "pixel" transparency simply as fully alpha transparent.)
Mostly happy:
Alpha transparency not catered for, but pixel transparency remembered from colour-indexed file.
In either case, the ability to render / overlay the loaded image over either another image or a specificed background colour (such that the background shows "through" appropriately) would be really useful.
If this is already possible in gflax 2.82 I'm not seeing it. All I get is the "colour" of the transparent pixel... I don't see any way of figuring out if that was actually supposed to be transparent or opaque, and no way of separating the "colour" of the transparent index a colour-indexed file from a matching opaque colour. eg if "transparent" is black plus another colour index is opaque black, I can't tell (a) what the transparent colour was at all or (b) which "black" pixels were / were not supposed to be transparent.
Is there a fix planned for transparency loaded from PNG/GIF?
jgrundy
Re: Is there a fix planned for transparency loaded from PNG/
I don't understand, you have TranpsrentIndex for 8bits, and alpha channel for 32bits
jgrundy
Then maybe I don't understand the library, or have the wrong thing.
I'm using GflAx.dll v2.82.0.0, dated 27/Feb/2008. (Light.)
The only class I can see published from this library is "GflAx".
This does not make public a "TransparentIndex" property, nor can I see anything which tells me what color index a pixel is. I have only a GetColorAt(x,y) method, which returns the translated color from an indexed image.
Suppose I have a PNG file with large regions 100% transparent
If I say...
oImg.LoadBitmap <png>
and examine oImg.GetColorAt(0,0) (which is transparent) I get FFFFFF
What I want to do is load a PNG file, make decisions about which pixels to make transparent based on the level of transparency in the original image, reduce the colour depth, and save a GIF.
If I say...
oImg.BackColor = <808080>
oImg.MaskColor = <808080>
oImg.ChangeColorDepth 64
oImg.SaveFormat = AX_GIF
oImg.SaveBitmap <gif>
The resulting GIF file has no transparent pixels, and the colour used for each pixel is approximately the residual colour from the original PNG pixel.
I do note that if I say...
oImg.SaveBitmap <new>
... then transparency info is preserved.
But I can't detect or manipulate any information about transparency through the gflax object. What have I missed?
Related... I in any way overlay one image with another, including transparency?
If I say...
If I say...
jgrundy
