Instead of the icons in the tool bar which I never use I`d prefer to have text-buttons.
That means buttons that all look alike and have text discribing the function instead of a symbol.
This should be optional since not everybody will like it this way but I would and maybe also a few other users.
Tool Bar: Text Buttons instead of icons (optional)
mostly harmless
Draw a skin---
• The tool bar provides buttons, anyway.
- Hence, just draw a bitmap skin having texts instead of images, following THESE INSTRUCTIONS…
- However, I think that the size of each “text-icon” must be large enough,
or else that could lead to display quite incomprehensible abbreviations…
- Forum Librarian
Just a couple of days ago I made me a “skin” which does exactly what you're looking for, mostly harmless:
- Create a sub-directory in %ProgramFiles%\XnView\skins\ and call it “null”.
- Copy & paste the following text into Notepad and save it as %ProgramFiles%\XnView\skins\null\info.txt:
Don't forget to remove all the trailing spaces phpBB puts at the end of every line/paragraph.
label = "null (Interface » Toolbar » Buttons » Show button text)" width = 1 height = 1 browser = 0 auto = 1 version = 3 main32 = 0 browser32 = 0 tabtree = 0 icninfo = 0 imbar = 0 jpgbar = 0 - Download 1z53rwm.gif (34×1 pixels), convert it to “Windows Bitmap” format and save it as %ProgramFiles%\XnView\skins\null\main.bmp.
- Restart XnView and go to Tools » Options....
- Enable the Show button text setting (Interface » Toolbar » Buttons) and select “null” as your skin (Interface » Toolbar » Skin).
Real skin vs. (Xn)Tri¦ck¦q
• Clever but a bit “lazy” solution… Using the buttons labels has a big disadvantage :
- In the average, the labels are wider than the normal icons, hence you can place less ones in a bar
(without the hellish extra-menu_list when that overflows).
• That I proposed above is a real skin, and I drew a quick-made sample (just the first items and the last one),
below as 37×41 pixels per item (same size than a skin of mine with images) :
• If some users requested such a “Text-skin”, I could draw one on demand, according to the users' wishes
(not too small, though, like I said above).
Note : I left the temporary marking off I use to draw skins
- Forum Librarian
Re: Real skin vs. (Xn)Tri¦ck¦q
Right, Clo. My “null” skin (if one can call it a skin) was meant as a quick-and-dirty solution or a “proof of concept” kind of experiment.Clo wrote:• Clever but a bit “lazy” solution… Using the buttons labels has a big disadvantage :
It would only make sense, if the toolbars were wrapable (as suggested by JohnFredC).
[ z00m ]
Skin to test…
• Just to test, I drew a text-skin as 35² per item, it's really the minimum size…
• Available to download HERE.
- Have fun !
- Forum Librarian
Re: Skin to test…
http://membres.lycos.fr/charries/icotext_en.zip » Page non trouvéeClo wrote:• Available to download HERE.
http://pagesperso-orange.fr/charries/download/icotext_en.zip
Wrong button
Thanks, it's corrected now !
