XnView 1.94 and ImageShack plugin. Where is the file going?
dvip
Post by dvip »
When I select a JPG in XnView 1.94 and click on
Tools->Plugin->ImageShack(1.03) it seems like the file is being
sent but I don't know where to... Is there a place to login to
ImageShack in the plugin? How does the plugin know where to
send the file to in ImageShack? How does this plugin work?
Re: XnView 1.94 and ImageShack plugin. Where is the file goi
The file is send to the public imageshack location
oops66
Post by oops66 »
dvip wrote:Hi,
Yes +1, it would be very interesting to have a small "how to" notice about this plugin, for example to know how to remove an uploaded image from this server, and so...
A small help is already here but personally I do not know how to remove an uploaded image to ImageShack server after the use of this plugin ???
http://newsgroup.xnview.com/viewtopic.php?t=1677
dvip
Post by dvip »
In my case, after I click on Tools->Plugin->ImageShack(1.03) it
takes a while and then nothing happens. I don't get a picture in a
website and I don't even know where the public ImageShack
location is so I can see the picture I uploaded and its link.
Does the plugin take you to the public ImageShack location
(website) by itself? Or do I need to go there with FireFox? If I
need to go there with FireFox what is the link to the public
ImageShack location? The plugin doesn't provide a links to the
image after the image is sent and it does nothing after the transfer.
Thanks
oops66
Post by oops66 »
Yes this will be a good idea than the XnView plugin give the links after the transfer (maybe into an historic text file) or a error message if the transfer was not good.
Here, when i use the XnView ImageShack plugin v1.03, I have only to wait (sometimes about 30 seconds or more), and then Firefox open a new tab with the ImageShack link and with the uploaded photo.
FYI: if you have a kind of NoScript plugin in Firefox (like me), you have to configure it before, to allow the ImageShack transfer .
Post by Guest »
I have ImageShack plugin v1.03 and XnView 1.94.
Some questions:
How do I know if I have the NoScript plugin in Firefox? and what
is the difference?
How do I configure the plugin to allow ImageShack
transfers?
So far I am not getting FireFox to open a new tab with the
ImageShack link and the uploaded photo after the upload
is completed.
oops66
Post by oops66 »
Anonymous wrote:...
is completed.
In this case, i don't think than this problem comes from NoScript plugin or else, maybe than your problem comes from the configuration for some associated files extensions with the right applications, but ???
But anyway, Pierre, it will be a good idea than the XnView plugin also gives the links after the transfer (maybe into an historic text file) ?
