Skins: Missing buttons in toolbar if “browser(32) = 0”
If you install a skin that has a browser = 0 & browser32 = 0 line in its info.txt and no browser.bmp or browser32.bmp file, ...... several buttons are missing in the small toolbar:
  • Back
    Forward
    Up one level
    New Folder
    Rename
    Delete
    View as
    Sort By
    Filter
    Refresh
    Favourite
Outdated in the EXE
:arrow: XnTriq
:) Hello !
• In such a case, I guess that the small bar embedded in the EXE (and NOT the default skin one) is used,
and IIRC, this bitmap could be outdated in some versions…
• Anyway, to use with your “null skin”, it can't harm to use the default bitmap (or any similar real one),
since the small toolbar wasn't the point, was it not ?
:mrgreen: KR
