more detailed documentation
xntest
Post by xntest »
Hello
Is there a more detailed documentation for nconvert anywere?
I want to resize some picture with nconvert in a batch but I do not find information about -c and -q.
It would be nice to see some examples with a short description.
Re: more detailed documentation
-q is for jpeg quality
and -c , you can take a look here:
http://newsgroup.xnview.com/viewtopic.php?t=12247
xntest
Post by xntest »
Hello
-q is OK for my understanding but I do not understand the funktion of -c.
I do not use -c at the moment and it works fine. Can I optimize resizing with -c?
Chris
xntest wrote:... -q is OK for my understanding but I do not understand the funktion of -c.
Unlike most file formats, the file formats PDF and TIFF allow for using various compression types (RLE, LZW, ...). To set a specific compression type you use the -c parameter. -c is only needed if your output files are saved as PDF or TIFF.
xntest
Post by xntest »
OK then I can forget it for my use.
Thanks.
