Alpha channel when creating Panorama images
Dark Schneider
Post by Dark Schneider »
I like that XnView is one of the few freeware programs that supports alpha channel for PNG, but I have encountered the problem that when creating a Panorama Image (join of multiple images in horizontal/vertical) the alpha is lost, as the default image format is 24-bit, you need to set 32-bit manually, but it is late, the alpha channel has been lost.
It could be good to support alpha channel in TGA too.
bye.
Re: Alpha channel when creating Panorama images
Dark Schneider wrote:I like that XnView is one of the few freeware programs that supports alpha channel for PNG, but I have encountered the problem that when creating a Panorama Image (join of multiple images in horizontal/vertical) the alpha is lost, as the default image format is 24-bit, you need to set 32-bit manually, but it is late, the alpha channel has been lost.
Ok, right!
But alpha channel from tga is already supported!!
Dark Schneider
It is true, is supported in TGA, sorry I confuse with other program.
tropics
Post by tropics »
Ok, right!
not sure if this is a bug or just never implemented, but it doesn't work in 2.25 :(
apart from that, great program and i've been using it for many years now.
