1.94 Slide show can't display some double bytes Chinese word
peorthyh
Post by peorthyh »
1.94 Slide show can't correctly display some double bytes Chinese words,
when setting Show Imformation,
example: "功","餐","許"
peorthyh
Re: 1.94 Slide show can't display some double bytes Chinese
Post by peorthyh »
another slide show problem:
when open the saved sld file(slide show file),the font setting doesn't load correctly,it becomes empty(color and size can load correctly).
Not suppordet---
:arrow: peorthyh
:) Hello !
• Xnview doesn't support the Unicode characters.
• The MP version does, but it's just an Alpha stage, please see THIS SECTION
:mrgreen: Kind regards,
peorthyh wrote:another slide show problem:
The font name use unicode?
