Opening subfolders from context menu.
Lostclown
Post by Lostclown »
When in browser view and bringing up the context menu when a subfolder is selected
and choosing 'Open', then nothing happens! But when pressing enter (the keyboard
shortcut for this action) the subfolder is however correctly browsed.
Other items that don't work on context menu when a folder is selected:
- Print
- Properties
- Shell
- Set as wallpaper
- Batch rename
- Web page
- Create contact sheet
Some of those items should probably simply be disabled when a folder is selected.
But my main concern here is that the 'Open' should work :)
Regards,
Lostclown
aardvarko
Post by aardvarko »
On a loosely related note - having context menu for the folder tree would be very nice.
edit: oops, there's already a thread about that.
Re: Opening subfolders from context menu.
Lostclown wrote:But my main concern here is that the 'Open' should work :)
Ok, i'll fix it.
