1.94.2: Option "Use different position/size for browser
Karl02
Post by Karl02 »
Tools -> Options -> Interface -> Use different position/size for browser & view
This option does not work reliably. After one time of correct behaviour the browser window is always resized to the size of the last image window.
-- Karl
Re: 1.94.2: Option "Use different position/size for bro
Do you have tried with clean .ini? How to reproduce the bug?
Karl02
Post by Karl02 »
Hi Pierre, with a new ini-file the bug does not occur.
Here is just one way how I could reproduce the bug:
- install XnView v1.94.2 from a zip file to a new directory
- remove or rename the ini-file in the application data directory if it does exist already
- start xnview.exe by doubleclicking
- set language to English
- set ini-file-location to program directory (application folder)
- click OK
- close "Tip of the day"
- go to Tools -> Options
-> Interface: check "Use different position/size for browser & view"
-> View -> View -> Auto Image Size: change "Fit image to window, large only" to: "Fit image to desktop, large only"
- click OK
- Browse to a directory with images
- unmaximize inner window
- maximize outer window
- open image in viewer by doubleclicking on it
- click on browser window
- doubleclick on image to switch back to browser
- et voilà: now the browser window always gets the size of the last viewer window
-- Karl
Karl02 wrote: - unmaximize inner window
You means the MDI child window?
Karl02
Post by Karl02 »
Yes. (MDI = Multiple Document Interface)
-- Karl
