Hello
There is a mysterious behaviour of XnView 1.91.1.
If I resize JPGs with the dimensions 4112x5984x24 to 50% it makes the pictures 2400x3000 pixel. The checkbox "keep aspect ratio" is checked.
Resizing of smaller pictures works well.
If I enter one deminsion instead of the percentage field it works fine. Then the aspect ratio survives.
aspect ratio is not kept with relative resizing
xntest
oops66
Re: aspect ratio is not kept with relativ resizing
Maybe you can try XnView 1.94.2 version, to see if this problem persist.
Karl02
