Xnview is very slow when display is in portrait orientation
my display has a really nice pivot-feature which allows me to rotate it into portrait orientation. Now if it is rotated that way, I have some trouble with XNview.
When opening the browser, the computer hangs for a few seconds, just long enough to be annoying. this happens between opening the browser window and actually displaying it's contents. It does only happen in portrait mode, if I don't have the display rotated there's no lag at all.
Would be nice if you could have a look at it,
Tobi
Tobi
No difference at all.xnview wrote:You can perhaps try the 1.94.2?
I did that already, I also removed xnview.db. Neither helped though. Another reason to assume that it's not related to any database issues is that everything works fine when the display is in landscape orientation of when XNview is on the secondary display which can't be rotated.Try to remove category.db?
Tobi
You have only this problem when you are in portrait? Strange...Anonymous wrote: I did that already, I also removed xnview.db. Neither helped though. Another reason to assume that it's not related to any database issues is that everything works fine when the display is in landscape orientation of when XNview is on the secondary display which can't be rotated.
Do you have problem with other programs?
Yes, only in portrait orientation. I absolutely agree, it's very strange...xnview wrote:You have only this problem when you are in portrait? Strange...Anonymous wrote: I did that already, I also removed xnview.db. Neither helped though. Another reason to assume that it's not related to any database issues is that everything works fine when the display is in landscape orientation of when XNview is on the secondary display which can't be rotated.
None that were obvious to me. In XNview everything works fine, it's just when I open up a browser window that the program slows down.Do you have problem with other programs?
Thanks,
Tobi
Nope, none at all. I just tried it: When in portrait mode, starting XNview takes a lot more time compare to landscape mode. There have no changes been done to the system: I just started XNview, closed it, rotated the display and started the program again.xnview wrote:In view mode you have no problem?Anonymous wrote:None that were obvious to me. In XNview everything works fine, it's just when I open up a browser window that the program slows down.
Tobi
When you have started it, no more delay after?Anonymous wrote: Nope, none at all. I just tried it: When in portrait mode, starting XNview takes a lot more time compare to landscape mode. There have no changes been done to the system: I just started XNview, closed it, rotated the display and started the program again.
If you close browser (not xnview), and restart browser, do you have always the delay?
None that I notice. My XNview is configured to open the browser window when I start it.xnview wrote:When you have started it, no more delay after?Anonymous wrote:Nope, none at all. I just tried it: When in portrait mode, starting XNview takes a lot more time compare to landscape mode. There have no changes been done to the system: I just started XNview, closed it, rotated the display and started the program again.
Yes. Whenever I open the browser. Doesn't matter whether that's when the program is running or when I just started it up.If you close browser (not xnview), and restart browser, do you have always the delay?
When the browser window pops up, all I see is the white background and the grey border lines. A while after that, the images and the folder tree appear as they should. In the time between seeing the white background and the images CPU load goes up and the computer almost freezes.
Tobi
Could you try in option/General/Startup dir : Specified, and clear the folder fieldAnonymous wrote: When the browser window pops up, all I see is the white background and the grey border lines. A while after that, the images and the folder tree appear as they should. In the time between seeing the white background and the images CPU load goes up and the computer almost freezes.
Right after opening the browser window, during the lag, it's completely empty, just plain white. After that, ready to be used, it just shows the basic struture of my hard drives. 'My computer', below that C:, D:, U:, V:, 'Common documents' and 'Tobi's files' and on the same level as 'My Computer' 'Networksomething' and 'Own files' (The actual names might be a little different, my system is german, but I guess you know what I mean.).xnview wrote:The folder tree is almost empty like that, right?Anonymous wrote:Makes no difference at all.xnview wrote:Could you try in option/General/Startup dir : Specified, and clear the folder field
Tobi
