fullscreen mode with info - blinking
orik
I use fullscreen mode vith info turned on (key I). Each time the picture is load the info is blinking two or three times. It's very unpleasant (even more when I use contrast colors for info). I tried to delete my INI file, but it is bad in the default configuration too. Please, how can I remove it?
Re: fullscreen mode with info - blinking
Really?? Do you use delayed resize mode?orik wrote:I use fullscreen mode vith info turned on (key I). Each time the picture is load the info is blinking two or three times. It's very unpleasant (even more when I use contrast colors for info). I tried to delete my INI file, but it is bad in the default configuration too. Please, how can I remove it?
orik
I tried it, delayed mode (on or off) doesn't affect this.xnview wrote:Really?? Do you use delayed resize mode?orik wrote:I use fullscreen mode vith info turned on (key I). Each time the picture is load the info is blinking two or three times. It's very unpleasant (even more when I use contrast colors for info). I tried to delete my INI file, but it is bad in the default configuration too. Please, how can I remove it?
orik
I found following:
The blinking apear only if I use full screen mode as default - in options - switching modes - browser <> fullscreen - viewer <> fullscreen !!!
But another bug - when I use browser <> viewer, the fullscreen is corrupt. I can send you captured screen of this corrupted fullscreen mode.
You dbl-click on a thumbnail, and you have blinking in fullscreen?orik wrote:I found following:
YesBut another bug - when I use browser <> viewer, the fullscreen is corrupt. I can send you captured screen of this corrupted fullscreen mode.
