JPG icons not updating on Vista Desktop
Ramzy
Post by Ramzy »
Hi guys,
Icons seem to be fine for GIF, PNG, and other file types, however the icons for JPG files are not updating.
Within programs such as Firefox and Internet explorer i can see the JPG icon just fine, Windows Explorer does not show the XnView JPG icon.
Here is an example:
I have tried rebuilding the icon cache, and re-associating XnView with JPG files, however this hasn't fixed the issue.
What can i do?
Thanks.
Change in Win
:arrow: Ramzy
:) Hello !
• Two ways to change the icon :
1. In Windows >> Start >> Parameters >> Config. Panel >> Tools Menu >> Folders Options >>
[File Types] tab >> Select JPG in the list >> [Advanced] button >>> "Change Icon" (or so, it's in French here).
2. If you are using Total Commander : Files Menu >> Associate with… >> Edit type >> Change Icon
:mrgreen: Kind regards
Ramzy
Post by Ramzy »
Thanks :mrgreen:
I fiddled with it for a bit and managed to get it working after multiple retries.
Thanks again :mrgreen:
