export image
paparaz
export image
Post by paparaz »
hi guys,
I have a problem, when i look trough with the arrow the images in a folder where i downloaded them ,if i chose one to save in a different folder with the save as button then i find myself in destination directory of the save as folder.
how could i keep browsing the same folder after i exported one file to a different directory?
thanks angelo
razpapa
Please have a look at topic Change "save as"-directory.
paparaz
save as with ?iptc template , is it possible
Post by paparaz »
thanks
for the previous answer it solved my first problem.
actually I have another one to solve...
would it be possible to add a personalized iptc template on the exported files ?
thanks in advance paparaz
