Disable Contextual window
pyv
Post by pyv »
How to disable the contextual window which appears each time you select a file in the xnview explorer
Re: Contextual window
pyv wrote:How to desable the contextual window which appears each time you select a file in the xnview explorer
Option/Integration/Use XnView shell ext
