When i rename a folder all rating info for the pics inside the folder is gone. Is it intendet to be like this? Where is the rating saved? I thought it would be saved in the pics itself.
thx,
Felix
Rating disappears when renaming folder
Re: Rating disapears when renaming folder
Rating are saved in xnview.db, and it's a known issueDocMucki wrote:When i rename a folder all rating info for the pics inside the folder is gone. Is it intendet to be like this? Where is the rating saved? I thought it would be saved in the pics itself.
