I've just unzipped xnView from the zip archive (not the windows installer) on my XP PC. XnView windows opens, but then it stops and I have to kill it in the task manager.
Did anybody encounter this pb ?
Thx
XnV crashes on XP when launched from the zip install
Re: XnV craches on XP when launched from the zip install
Try to drag&drop a picture on xnview's icon?
laurent
It works. Launching xnview.exe seems to work also now. Curious...it did not work for days, and now it works...xnview wrote:Try to drag&drop a picture on xnview's icon?
Thanks for your answer, I'll post again if it crashes again.
