is it possible to select a default destination folder?
paparaz
Post by paparaz »
hi ,
when i use your shell extension tool to convert files (normally resize them)
i save them always in the same directory , so i have to navigate to this directory each time
thanks paparaz
oops66
Re: is it possible to select a default destination folder?
Post by oops66 »
paparaz wrote:hi ,
thanks paparaz
Yes, (Ctrl +u) and Output directory --> "your directory"
paparaz
tried but not working
Post by paparaz »
let say i want to convert some resize some picture from folder C:a
to folder C:b
i look trough the pics in folder C:a when i like one i want to resize and send the resized copy to folder C:b
with xn shell extension i have to navigate each time i want to convert the pic to the path C:b starting from C:a
is there a way to make C:b the default destination folder?
i tried ctrl u but nothing happened
thanks paparaz
paparaz
checked out the shortcuts
Post by paparaz »
i checked out the key board shortcuts, and and saw how to use it
but it does not answer to my problem
whenever i convert a file with xn shell extension i have to find the path to the destination folder where i want to save it.
is there a way to leave last used folder , or have a choice of favourite folder or make a default destination folder?
thanks again for your patience paparaz
