NConvert on Apache Linux server
supermix
Post by supermix »
Hi, sorry for my English but I'm writing from Italy and I'm not very able.
I'll need to install nconvert in my web space: the server in Apache linux but unfortunately I don't know linux language so I don't kow how do!
In What way Can I call the command line to installing nconvert on the server?
Plesa help me!!!
Re: NConvert on Apache Linux server
You must put nconvert in the cgi-bin folder to be able to use it
Post by Guest »
Unfortunately I haven't permission to that folder
You don't have permission to access /cgi-bin/ on this server.
... I have just asked the server to give me the permission ... I'll tell you ...
so thanks
supermix
Post by supermix »
I have put nconvert in cgi-bin folder but It doesn't work ... it doesn't give me any error
I have the following php file in the root
<php>
why it doesn't give me any error?
if i write
<php>
i get the list of file so i think it isn't a problem of permission ....
... suggestions?!?!?!
nconvert can be executed by 'other'?
What is the error?
supermix
Post by supermix »
nconvert doesn't write any error so I can't understand what is the problem...
... do you know if somebody has put nconvert in a linux web server and how he starts the program?
... do you know if I should ask the server any other things as for example libraries or other things to set?
Remember, I don't know linux operating system
help me
If it will works I'll need 3 licence (I don't say this to force yuo to help me... It's true!)
I use nconvert on a server with php, and no problem.
Do you have tried chmod 777 nconvert?
On a console, you can start nconvert?
supermix
Post by supermix »
Yes I have tried chmod 777 for nconvert
I have tried nconvert for linux on a console but It says me I haven't some libraries ... I don't know how run a console in the server, moreover is a condivided server!
supermix wrote:Yes I have tried chmod 777 for nconvert
What is printed on console? Which linux do you have?
cyrille42
Post by cyrille42 »
Hello and sorry for my bad english.
I have a question related to this post.
I have put the nconvert in the cgi-bin folder.
I have some difficulties to use it can you give me an exemple for use it in php.
Thanks a lot
system($command, $ret);
and $command is something like "/cgi-bin/nconvert ......"
cyrille42
Post by cyrille42 »
I try but nothing append.
May i should put another files or something else in cgi-bin folder?
I also try with a server install and result is the same.
Maybe my server is not compatible.
My server : Gentoo Linux
Thanks for your answer.
cyrille42 wrote: May i should put another files or something else in cgi-bin folder?
no, do you have tried nconvert > log?
cyrille42
Post by cyrille42 »
I just try on my page in php i have value 139 displaying.
And on my server with a shell i have the following error : /bin/bash: line 1: 31806 Segmentation fault ./nconvert > log.
Which version of Gentoo? 64Bits?
