Hi Guys!
I have a problem and can't mannage it...
When I try to convert CR2 Files into jpeg or PSD files XnView just halves my pics...
I would like to convert several pics with a resolution of about 3000 x 4300 pixels, but if I do so the resulting pics have only a resolution of about 1500 x 2150...
But I need the full the resolution to print some posters...
Hope you can help me!
Thx
Batch converted CR2 files have only half size
mcaron
Now it works perfectly, and the end-resolution is the same as the start-resolution, thanks.
But it takes ages to convert some pics...is there a way to improve it? Or is it because I set the quality at highest possible?
And another question...does it make sence to put the option "keep starting size (if possible)" ?
