is there a way to configure XNview to always display the newest file in a folder? I have a camera I often use for tethered shooting, but the manufacturer's software is not good at all. It works alright for storing the images on a PC, but is displaying them satisfactory. I'd rather look at the images using XNview.
Thanks,
Tobi
Always display newest file in folder
Re: Always display newest file in folder
but is not displaying them satisfactoryAnonymous wrote:but is displaying them satisfactory
You means start xnview on a folder, and with external tools add pictures in this folder?
Yes, exactly like that. The pictures are being stored directly to the computer when I press the camera's shutter.xnview wrote:You means start xnview on a folder, and with external tools add pictures in this folder?
Tobi
I files are added in a folder (currently viewed by XnView), XnView must update the file list...Anonymous wrote:Yes, exactly like that. The pictures are being stored directly to the computer when I press the camera's shutter.xnview wrote:You means start xnview on a folder, and with external tools add pictures in this folder?
Something like that would be great, but I guess it's not possible right now, is it? An 'always display newest file' feature would be really neat.xnview wrote:I files are added in a folder (currently viewed by XnView), XnView must update the file list...
Tobi
I means XnView already update the file list, so it's strange that doesn't work for oyuAnonymous wrote:Something like that would be great, but I guess it's not possible right now, is it? An 'always display newest file' feature would be really neat.xnview wrote:I files are added in a folder (currently viewed by XnView), XnView must update the file list...
Ah, ok, that's what you meant. Sorry, I misunderstood you.xnview wrote:I means XnView already update the file list, so it's strange that doesn't work for oyu
On my machine, XNview only updates the file list if I hit F5. It does not if there's a new file being stored into the directory. Do I need to have any special settings?
Tobi
No, and if you add a file with windows explorer, xnview detect it?Anonymous wrote:Ah, ok, that's what you meant. Sorry, I misunderstood you.xnview wrote:I means XnView already update the file list, so it's strange that doesn't work for oyu
No, it does not.xnview wrote:No, and if you add a file with windows explorer, xnview detect it?
I tried by running XNview while copying a file into the folder XNview was displaying. When I copied it, XNview didn't notice.
Tobi
Dstruct
