Problem with saving pictures with GflAx [VB]
Erik
Post by Erik »
I have problems with trying some code to save a picture from a standard picturebox in VB. It crashes when I ultimately want to save the file. The code I use is as follows (where picturebox is the standard picturebox on the form that holds the image):
m_strFileName = "D:\Test\Block.jpg"
Dim Myobj As GflAx193.GflAx
Set Myobj = New GflAx193.GflAx
Myobj.SaveFormat = AX_JPEG
Myobj.SetPicture pictureBox
Myobj.SaveBitmap m_strFileName ' this is the code that fails
Set Myobj = Nothing
What am I doing wrong or do you know what's going on?
Erik
Re: Problem with saving pictures with GflAx [VB]
First I must say, that I'm a real GFL SDK newbie, so my advice might be completely wrong.
The error code raised would help to find the problem. I assume that you get a "-2147220504 No file opened".
Since you do not load an existing bitmap using GFL SDK, I assume that you have to call NewBitmap first. So your code should change to something like:
Myobj.NewBitmap pictureBox.Width, pictureBox.Height
Set Myobj = Nothing
I am not quite clear and sure how to set the width and height parameters of .NewBitmap properly, but for me the code did work.
Erik
Post by Erik »
Thanks, I.ve got it to work. Would you know how to save tiff files in compressed format using the DLL version?
Erik wrote:Thanks, I.ve got it to work. Would you know how to save tiff files in compressed format using the DLL version?
Change Compression in GFL_SAVE_PARAMS.
