1.95 B1 - Icons - Previous/next page issue
Dreamer
Post by Dreamer »
In view/edit mode it's working good - using the shortcuts (shift+page up/down, or up/down) the pages are switched from first to last and vice versa, but in browser mode (fullscreen) using shift+page down wrap around is enabled. Just a minor issue, but it should be the same in both/all modes (viewer/fullscreen and browser fullscreen). In this case it's not the same (shift+page up / shift+page down) even in the same mode.
Dreamer
Re: 1.95 B1 - Icons - Previous/next page issue
Sorry i don't understand, Shift+Page up/down is used in view mode & fullscreen mode (view-browser)...
Dreamer
Post by Dreamer »
OK, I'll try to explain.
In viewer and fullscreen edit:
Shift+PageUp and Shift+PageDown are working as previous page / next page, wrap around is disabled.
In fullscreen browser:
Shift+PageUp is working as previous page, wrap around is disabled, Shift+PageDown is working as next page, but wrap around is enabled - the page is changed from last to first.
So even in the same mode for previous page wrap around is disabled, but for next page it's enabled.
Simply use the Butterfly.ico from me and hold Shift+PageDown in viewer and in fullscreen browser and see the difference.
Dreamer
Dreamer
Post by Dreamer »
You said all bugs should be fixed in beta 2, but this one is not fixed, it's still the same.
Dreamer
Dreamer
Post by Dreamer »
Not fixed in RC1.
Dreamer
Dreamer
Post by Dreamer »
Still the same, postpone?
Dreamer
Dreamer
Post by Dreamer »
Moved to Bug reports.
Dreamer
