Reset X/Y -> Dependency of Lock Zoom
vladivostok
Post by vladivostok »
For me this is strange behaviour:
When "Reset x/y" is disabled, the current image position will only be kept on the next image in view-mode, if also "Lock Zoom" is enabled.
If "Lock Zoom" is disabled, the "Reset x/y" (without checkmark) will lead to centering of next selected image.
For me this is strange behaviour. Either someone explains, or it is a bug ;)
Tested with 1.95 B1, but it is the same with previous versions...
Dreamer
Post by Dreamer »
Similar (or perhaps the same?) bug:
http://newsgroup.xnview.com/viewtopic.php?t=15329
Dreamer
