DNG format supported?
unionjak
Post by unionjak »
Is XnView able to save or convert RAW(cr2) files to DNG and if so how ?
Many thanks,
steve.
Re: DNG
unionjak wrote:Is XnView able to save or convert RAW(cr2) files to DNG and if so how ?
From what I can see DNG is not supported, see Does XnView support graphic format .xyz?.
A specification of the Digital Negative Format is provided by Adobe, perhaps Pierre could implement this and support DNG. Is DNG a commonly used format?
darrask
Post by darrask »
XnView can read DNG, but it cannot read all the specific tags contained in DNGs, like BaselineExposure, BaselineNoise...
Here are the DNG specifications:
http://www.adobe.com/products/dng/pdfs/dng_spec.pdf
jaqian
Post by jaqian »
It would be great if we could convert RAW files to DNG
