Selected bitmap moved automaticaly on the screen
OMT
Post by OMT »
I'm a little ( very litttle ) bit disapointed why the the traitment of the selected bitmap.
If I answer to XNV to display 'Thumnail & details' with size '192 x 144',
if the screen area for this list of thumbnails is inferior to this height choosen
(iex: I resize this area with my mouse to 165 pixels height),
when I click on a thumbnail in the list, I'm suprised:
* the preview of the bitmap, histogram, etc is correctly displayed on the bottom of the screen
* in the area of the list at the top of the screen, XNV display automaticaly the next thumbnail !!
In this case, informations on my screen are desynchronised: the thumbnail showed in the list at the top is different than the preview at the botom...
Re: Selected bitmap moved automaticaly on the screen
Could you post a screenshot please?
OMT
Post by OMT »
OMT wrote:Here is the screen-shot:
http://img155.imageshack.us/my.php?imag ... 916vw9.jpg
On your screenshot, i can't see which thumbnail is selected...
OMT
Post by OMT »
It's normal that it is not showed in my screenshot because it is the description of this bug.
When I select a thumnail in the area at top of the screen (list of thumbnail + détails):
* it's details are correctly displayed at the bottom of the screen (--> cf screenshot)
* but XNV pass to the next thumbnail in the area at top of the screen (list of thumnails + detail) (-->cf screenshot)
To reproduce this bug, U can just resize the area at the top of the screen (list of thumbnail+detail) to a vertical size < at the vertical size of the thumbnails.
Oh i think that i undestand the problem.
You select a thumbnail, the preview is loaded, and the thumbnail view is scrolled, now you see only the next thumbnail, right?
If so, it's the behavior of windows list, i can't change that
